Old 02-01-2007   #10
x-pride
x-pride's Avatar
Re: DSM Parts I Need OUT!
Originally Posted by Mr.98GSX View Post
You dont happen to know which one I need do you? 98 gsx
1G Throttle Body
  • Must be from a June '90 thru 94 car ('91-94 model year). The correct one has 4 vacuum connections on the top of the TB facing towards the passenger side of the car. The earlier '89-May'90 TB has two fittings on the top and two on the front side, this one will not work. You will re-use your 2G Throttle Position
    Sensor (TPS). The 1G TPS has only three wires while the 2G has four. The Idle Speed Controller
    is the same between the cars.
Hope this helps.
