Old 02-22-2007   #11
Re: Recommendations for a local Machine Shop
Stock rods usually break or bend before stock pistons.
You will want some way to tune the timing on the car. Raising the compression from 7.8:1 or lower(worn motor) to 8.5:1 or higher after deck/head milling usually turns the car into a detonation machine with the stock ECU and the boost levels we normally run on pump gas.
