Old 03-12-2007   #2
xveganxcowboyx
Wanker
xveganxcowboyx's Avatar
Drives: 95 M3
Re: Decision troubles
I mentioned this to you before, but I had my 16G on befor einjectors and fuel pump. I was able to run 14-15psi. At 15 it started knocking from 6K up, but that was mostly due to the fuel pump running out of steam. The unjectors were running high duty cycles, but supplying enough fuel as long as the fuel pump could match.
I don't see any problem with running that setup as long as you can keep the boost low.
