Old 03-21-2007   #4
Re: Hardwired I-pod setup?
I wanted the ability to use my ipod, but I didn't want to spend the big bucks for that whole radio/wire setup.
This is a much cheaper (free) solution if you already have the amp. If not, you can get a cheap deck with RCA input for < $100 on sale online.
But yes, hooking up the amp's speaker outputs to the car's harness speaker inputs should work, using the ipod as a direct input to the amp. There really isn't any way to harm the ipod, because the amp is using the RCA plugs as an input.
That's going to be ugly though, ipod wire going to amp sitting somewhere in center console, big hole there and all. Unless you figure out a way to mount the amp in the double DIN slot... which would be different but kinda cool.
