Old 03-28-2007   #1
runninW.O.T.
Where is my custom title?
Conquer Antartica Champion! Herculympics Champion! Hybrid Fighter Champion!
Engine Knock
My gas V6 sounds like a diesel at the moment.
My first thought was that the timing needing to be replaced. But it doesn't sound like a timing belt issue.
Any Ideas?
runninW.O.T. is offline   Reply With Quote
Old 03-28-2007   #2
Re: Engine Knock
You'll need to diagnose exactly where the noise is coming from. Drain your oil and see if you've got metal flakes or the oil shimmers in the light. You might have a rod bearing about to go.
Old 03-28-2007   #3
Re: Engine Knock
If it is a hard metallic knock I would agree with Steve. If it is just missing then I would check plugs & wires.
Old 03-29-2007   #4
runninW.O.T.
Re: Engine Knock
It is a hard knock.
Near as I can tell it is isolated on the back bank.
Old 03-29-2007   #5
Re: Engine Knock
Rod bearing spins and then the piston starts to hit the head, its sweet.
