Old 04-03-2007   #7
gstjoker
gstjoker's Avatar
Re: Bad gas mileage
Originally Posted by b00stcreep21 View Post
Did you set the fuel pressure regulator with the vaccum line disconnected? If you say it happend after you put the afc in, and it's just zero'd out, unplug the afc and see if it gets better. If it doesn't, you either fucked up your afc wiring REALLY badly, or the problem is elsewhere
I did set the fuel pressure when the vaccum line was off. I'll try unplugging the afc tomorrow when I don't have work and see if it get's any better.
