Old 04-07-2007   #14
Re: little problem... boosting too much
The wastegate probably just isn't flowing enough, I doubt it is bad. You can adjust the arm some. It should just BARELY push on the wastegate to keep it closed. That will allow it to open as much as possible. If that still doesn't cut it, then you will probably have to have the wastegate ported.
