Old 04-09-2007   #15
Pianoman
Re: F/S 2g with built 6 bolt/50 trim 6000/bo
Originally Posted by Tenacious2g View Post
To get it back to running condition just need to slap in some rings. It ran PERFECT before the ring went bad (-26psi on decell) and still reads that. I pulled the plugs and couldn't see any imperfections on the piston. Most 2g's with a 6 bolt have the random misfire but mine doesn't. It does start like a frickin pig but that is only when the block is cold. After the block is warm she runs fine.
You cant just slap in some rings and call it good. What caused the ring issue before will most likely cause it again.
Pianoman is offline   Reply With Quote
