Old 04-12-2007   #24
Re: little problem... boosting too much
Run a line from the compressor housing to the waste gate, if it still runs to much boost check your waste gate actuator with a pressure tester should be full open in the 15psi range. If all that does not fix it then you need to port out the waste gate hole and try a different o2 housing (either a LIPP or similar).
