Old 05-03-2007   #12
Re: is 5 deg BTDC ok?
Yeah i set the timing on the crank at 5 degrees BTDC. So ill have to change that to TDC.
I havent done a compression check yet.
Tonight when i get home im going to go over everything and change out the Fuel Injector Electrical plugs.
Would bent valves cause it not to start, or would it just run like crap? The car will just continue to turn and just wont fire, I have spark. I dont know how to check whether the injectors are firing.
