Old 05-24-2007   #8
DBMajik
Re: Aem Ems
Originally Posted by EclipseGST View Post
Since it doesnt matter on the "base tune" to get you to DB, bring up the fuel map and select the first 3-4 rows up (vac-boost) and 4-5 rows to the right (RPM) up to say, 2000rpms and start tapping the "+" key to raise the fuel until it idles. This will get you by to DB.
Make sure you select the "MAP" calibration. Go into the sensor menu and make sure the AEM 5 bar is selected and do the same thing with the IAT sensor.
Hope this helps a little.
Thanks I'll see how that goes.
Did you ask shane to send you a basemap, since you are getting it tuned up there?
I'm speaking with him in PMs about it right now. I like fiddling with stuff myself, that's the reason why I'm asking others for suggestions.
DBMajik is offline   Reply With Quote
