Old 07-26-2007   #16
Re: Compression
Originally Posted by DWs97GST View Post
First off the numbers being that low ALL the way across probably means ur tester is off a little. BUT it doesnt make a diffrence because you have to much of a diffrence between compression therefore there is a problem somewhere. I would suggest a rebuild. NOW if it kinda takes off slow and gradually get better it could be because as u go you build compression. If one of your cyl is not sparking because the compression is too low then once it build up a little from moving then you will get spark and gain that cyl back.
Umm wrong.
Post started okay then turned into a rambling mess of useless brain spew. I'd suggest to do a bit more research before giving technical "advice".
