Old 08-18-2007   #1
kennydawgg
CMP Camshaft position Question
I was reading my book trying to figure out my no spark issues and I found this about the CMP which I assume is the same as what everyone calls the CAS.
from chilton:
"The computer uses the CMP sensor to determine the position of the no 1 cylander durring the power stroke. the signal is used to calculate fuel injection mode of operation.
if the cam signal is lost while engine is running, the fuel injection system will swithc to calculated fuel injection mode based on the last fuel injection pulse, and the engine will continue to run"
from my searches people were saying to check the CAS as a source of problem for not having spark but what I am reading seems to contradict what others are saying. anyone know anything about it?
thanks
kennydawgg is offline   Reply With Quote
