Old 09-16-2007   #3
driftn1g
Re: tuning safc2 for 14b, 550cc, maft
im on 92 pump with a 255 pump and an ebay FMIC... i opened up my translator and set everything back to zero and it made everything better.. havent had too much time messing around with it but the max i got was 9 counts with 93% d/c, but still breaks up at 5k just cuz its so rich.. im going to lower it on the safc2, which im sure will be fine afterwards.. my trims are 90-100% which i believe is good.. all in all, im glad it aint running lean, as far as heat goes, my temp stays around 189-194 on a stock 7-bolt 1g block with 160k+ miles .... but should i be messing too much with the LOW setting on the safc2?? is that for MID throttle 1-8 psi??
