Old 09-16-2007   #2
crazy_skier
A.E.K.Δ.B
crazy_skier's Avatar
Beer Dude 2 Champion!
Drives: 1994 Suburban
Re: SAFC2 help!
those numbers seem to be in the right range, and sort of following how I had my safc set up, except I was running 680cc injectors so it was alot higher on the %'s and I had my low thr at 25% and high at 75%. I would highly reccomed getting a logger and going from there, they are not to much and will save your butt (so you dont blow it up). Also, what do you have for vital monitoring aka wbO2, egt gauge, oil press gauge?? I would reccomend getting a wideband if you have neither of them, since you can tune for an a/f ratio of 11.1 and you should be more than on the safe side with your egt's. Also, what psi are you running for boost.
