Old 09-29-2007   #3
Re: quest+AEM+fuel+spark = no start. help?
Originally Posted by MustGoFaster View Post
Sounds like your close, did you try giving it some throttle while cranking? With an AEM it's fine to do so, you will be leaning out the mixture (assuming it's set up the normal way). 1-4-2-3 should be right, but you could always try swapping them around. 2-3-1-4. Did you get any attempts to fire?
When you say computer, do you mean a laptop or a more desktop type deal?
I meant laptop computer with a battery that doesn't work, so I need to always have it plugged in, but I was thinking that the 12v cig lighter plug doesn't get juice when I crank, so I didn't test that theory, I just turned off the computer.
All the aem stuff was plugged in, of course. I am in a difficult position with playing with the car, I only get to see it on fridays, like a prisoner or something.
As for the spark plug order, Jet's saying it might be 2-3-1-4, and you mentioned it once, so I'll try that. And I didn't give it any throttle, it didn't cross my mind, I'm used to factory starting setup, lol.
