Old 10-04-2007   #11
Re: Evo X
That is why the Honda guys put a block guard in, like so:
That turns an open deck into a semi closed deck, the 4B11T will come with something like that installed from the factory.
The Honda guys stopped using block guards a while ago. They usually only made things worse, since putting them in distorted the cylinder placement and the sleeves often cracked at the bottom anyways. You can get farther on the stock Honda sleeves than people used to think 5 years ago, but if you want to run big boost reliabily you need to sleeve it or buy a closed deck Dat Honda block.
