Old 10-08-2007   #15
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
Re: quest+AEM+fuel+spark = no start. help?
I was talking about to make it stay running, typically unless it's fog you out rich and the car won't stay running, it's too lean.
If your new map is similar to the one you sent me before you will need to take cranking fuel out. Open up the starting template and you will see a TPS VS. Cranking fuel table. Adjust this table to adjust fuel delivered for cranking. Since you are having to open the throttle to get it to stumble, you will need to take fuel out (unless it's stumbling only when the throttle is closed)
