Old 10-27-2007   #1
Overheating
First off, completely stock 7 bolt motor on my 96 talon. No ARP headstuds or anything, the engine head probably hasn't been off the car even. I recently put on a 20g turbo, but everything has been going pretty well since then, no huge problems. At the dyno day it was blowing smoke after each run, not sure if it was gray or white smoke, but I figured it was because it was running super rich, way less than 10/1.
My car was running fine until yesterday, when out of nowhere it's running way too hot. Since I put on the new turbo I've only floored it in 1st gear a few times, but several 2nd and 3rd gear pulls. Yesterday after work I decided to have fun at WOT for 1st through 3rd gears. 5 minutes later the temp guage was pegged at hot and all the coolant is bubbling and overflowing. I had a gallon of water in the trunk and waited for it to cool off, refilled it, and started driving again. The temps just kept rising, and it would cool off a little when idling. Even going 40mph in 5th gear it overheats, but not at idle, just any little amount of load.
So I thought I blew a headgasket and starting checking things today. There are no obvious coolant leaks, at least nothing is dripping out coolant all over the ground, nothing that would make it overheat in 5 miles of driving. I did a compression test, results are something like 170, 175, 190, 190, and the tops of the pistons looked dry. It's about a quart low on oil, I was just going to change it this weekend. It's also been using a little coolant since I got the car, but nothing really unusual, I just have to put more in the resovoir every 6 months.
I also checked the pully for the water pump, it's not loose or anything, and all the belts seem to be in place with good tension, nothing is slipping. I haven't checked if anything is wrong with the heater core yet.
Any suggestions on other things to check tomorrow? I'm out of ideas, and I dont know how to do a leak down test. I'm stuck in Des Moines, so I can't take it to any of the shops up there. I have almost all my tools here though so I can do quite a bit, but a headgasket may be tricky here since I've never done one.
