Old 11-25-2007   #11
Re: Make slowboy not so slow
Ok, much more progress today. I got the alternator and power steering pump on the new motor, got the cams installed too. When I got the valve cover off the old motor everything was really yellow inside, not much silver that I could see. I had to use the hydraulic lifters out of my motor and put them in the new one. All that is left now is to get the timing belts done and bolt on the transmission, then it will be ready to be put in.
Oh, I also got the motor mount ground so it fits with the 1g water pump, that's bolted on too. I'll probably put the turbo on it tonight as well. The AC lines and stuff are all out too.
