Old 01-04-2008   #15
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
Re: My Stealth TT, dealth, then revived
Yeah, this is the one. Everything's for sale, for the right price. With everything it's got on it now I'd want a lot more. 6000ish, probably a little less. That's off the top of my head, but that's the "You can have it if you make if worth it to me" price.
As far as the turbo's, it really depends on the rest of the setup. I'm not trying to get all I can out of them, I'm looking to get 300-350. That should be at the limit of the mild clutch. They should be able to do ~400.
It would be better if I had the upgraded exhaust wheel. Mine have stock WRX exhaust wheels. Stock for a 3S is TD04. The WRX's are TD04L, they arn't much bigger. TD04HL is a lot bigger (about 1/4"). TD04HL 19T's have done 550 AWHP on race and 513 on pump with heads and cams. But that's on a DD where the used the X key, so not quite that much for those of us around here. About 430-450 on pump with heads and cams, 475+/- on race with out H/C. Both those # are from the same guy.
As far as not telling you, I was going to eventualy.
