Old 03-09-2008   #11
iceminion
iceminion's Avatar
Re: Venturi vacuum pump
Does it not connect to the same place as yours?
I really wish you had asked a more complete question.
In short, yes, it does connect to the crank case vent -and- to the pcv (basically a backup pcv valve)
but it does not apply vacuum at all, it only stops air from flowing INTO the crank case.....and seeing how the stock line goes to the turbo intake pipe (small amount of vacuum) no air would travel back up that line anyways.
this KV product will solve the problem of a defective PCV valve, but that is the only thing it will do, and for $110, I would rather buy a mitsu pcv valve and be done.
building a 3000GT AWD Turbo.
