Old 03-10-2008   #6
crazy_skier
A.E.K.Δ.B
crazy_skier's Avatar
Beer Dude 2 Champion!
Drives: 1994 Suburban
Re: master cylinder
try adjusting your master cylinder, and then check both the master and slave for ANY leaking oil after bleeding the system if the adjustment doesnt work. Otherwise I would drop the tranny and see if the clutch fork is bent, the extended rod will only hid a problem in the system which will get worse over time.
