Old 03-12-2008   #7
Re: Aquamist HFS-1 alky kit
Well it was *really* nice out today and after a few days out of town I was excited to get some time in on this project. First thing I did was yank the tank and flip the float sensor over into the correct orientation, I felt like a dumbass about that one but it was nice that everything came apart so nicely
I then ran power and my small hose to the engine bay, and mounted the flow sensor and valve to the right of the glovebox (thanks for the tip KevinD!). I am focusing on keeping the wiring as clean as possible so I did not finish tonight.
Extra hose wrapped up in case I want to extend this bit further into the engine bay:
Mounted valve and flow sensor (tucked to the right):
All is well when everything is where it should be and you end up with this. Wiring leads for all of the sensors. Thank you aquamist for keeping everything semi color coded!
Nice and tidy:
There's a nice spot just above the glove box that this will be secured to. For now its just in the glove box while I test everything out and get the DDS dialed in. The wires to teh top right will be tie wrapped a bit more so they're all out of the way:
