Old 03-16-2008   #24
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
Re: New guy on the DSM scene.
First I will have to say welcome..... Also, I had the same problem with the fuel cut and at about the same rpm in the same gear.. I was running a 16G on stock injectors. I then went to LSE and had some stuff put on like 680cc injectors, 255 walbro lph fuel pump, ect.. and all the issues ended at that...
I would double check and make sure your not running stock injectors and go from there, maybe get a safc2 that will better tune your car
For the idle, yes that is too low and I am currently having that same issue of idleing low but mine won't die. I would have to say try adjusting the screw a little and see if it sticks to about 800-900 rpm's
The wheel baring is a BITCH!! I had to replace the same one about a year ago and the hub was completely stuck on the axle and it took like 21,000 lbs. of pressure to get it free and yes it wrecked the axle and had to be replaced for $800 trust me it sucks and your gonna need help on it.
Good luck with everything and once again WELCOME!
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
