Old 03-08-2004   #5
JustROLLIN
SpunBearing
JustROLLIN's Avatar
Also, the springs can pivot out of there grooves causing a snap when they are compressed. (IE - Under accel.) Make sure the springs are seated correctly. There is a small notch on the bottom end of the spring where the very tip of the spring should settle against. If the spring has rotated, the tip of the spring will no longer be resting against this notch.
Kiel, YOU DUMBASS.
Joooeeeyyy
