Old 05-19-2008   #3
mdost03
Sonic Champion!
Drives: VA STI
Re: Please help, leaking coolant
Originally Posted by xveganxcowboyx View Post
The pipe fits into the outlet of the water pump where it's leaking. There is an o-ring that fits in them. Mitsu should have it. You'll have to remove the water pipe, or at least be able to pull it a couple inches toward the passenger side so you can put the new o-ring on. probably have to pull the turbo coolant lines.
Turbo is just oil-cooled so shouldn't have to worry about that. I am kinda hoping I don't have to pull the manifold and turbo back off to fix this, but if I have to, I have to.
Originally Posted by 311evo View Post
Good luck getting it all buttoned up mike, it should be a blast when everything is said and done. i know youve allready put alot of time into it, so i hope you can catch a break pretty soon here. Were you able to test spool up with the new gaskets?
Nope, not yet. Got everything put back together and go to refill the coolant I spilt and it started to drip there. Jungy may come and visit tomorow to help out and hang out.
Thanks for the help guys, going to start on it first thing in the morning.
