Old 06-01-2008   #19
HiImBrian
HiImBrian's Avatar
Drives: the girls crazy
Re: SMIC with big16g?
If you were to just throw on a 16g you probably wont make more power unless you adjust your fuel setup so you can raise up the boost. One thing you need to consider is 14psi on a 14b is much different than 14psi on a gt42r haha. So yea on a 14b you can push the boost up a little more than stock, but with a 16g, 14psi is already somewhat more than stock. lmk if that doesn't makes sence, I just woke up.
You could probably get away without an afpr for now, but I would look into it in the future. You could also probably settle for an safc instead of the spendy dsmlink if you aren't planning on making mad power. I would stay away from chips for the only fact that you can't modify your own tune as far as I know.
pics or gtfo
