Old 06-23-2008   #11
hotrodbrett
hotrodbrett's Avatar
Drives: 99 eclipse work in progress
Re: two and half year project so far.
Yes I run a resitor pack. The injectors dont preform properly with out it. And as I said befor I am trying to blow it up. Because the block is junk and I want to be able to run power steering. the bolt holes on the block for the power steering and motor mount are broke and one hole has a bolt broke off in side it. So the block aint worth much at all and it is a good test bed for wat it can handle. Once I get the other motor built I will put all the tuning parts in. Like a new ecu, fuel lines, better exaust hook up other then a coat hanger and neon 5 speed tranny with lsd.
hotrodbrett is offline   Reply With Quote
