Old 06-27-2008   #41
hotrodbrett
hotrodbrett's Avatar
Drives: 99 eclipse work in progress
Re: two and half year project so far.
Well I have been trying to blow the motor I tried to run 30 psi of fuel at idle and 10 psi of boost. yea it is stupid but i want it to go boooooom.
hotrodbrett is offline   Reply With Quote
Old 06-27-2008   #42
mdost03
Sonic Champion!
Drives: VA STI
With 450cc injectors, you want an idle fuel pressure closer to 20 psi or even less. Problem is with that, fuel pressure begins to go too low for the car to run well.
Old 06-27-2008   #43
If you aren't blowing it up, raise the boost
Old 06-27-2008   #44
Throwing a ton of fuel and not much boost isn't gonna blow it up. It should be the other way around.
Old 06-30-2008   #45
hotrodbrett
well 10 psi of boost and 20 psi of fuel.
Old 06-30-2008   #46
mdost03
Sonic Champion!
Drives: VA STI
And?
Old 06-30-2008   #47
hotrodbrett
I have the 235 cc back in also. I swapped them out just this last friday. I run80 psi of fuel. That way wen I boost to 10 it dosent run to lean but the idle is better. I raced a 02 grand prix gt and a 99 ford escort zx2 5 speed. they got spanked.
Old 06-30-2008   #48
hotrodbrett
nothing happend just lots of predetition.
Old 06-30-2008   #49
Um, are you joking?
Old 06-30-2008   #50
mdost03
Sonic Champion!
Drives: VA STI
Um, are you joking?
I hope so.
Old 07-10-2008   #51
hotrodbrett
Honestly no I tried to blow the engine that way.
Old 07-10-2008   #52
crazy_skier
A.E.K.Δ.B
crazy_skier's Avatar
Beer Dude 2 Champion!
Drives: 1994 Suburban
take the vaccum line off the wastegate and go rod on her for an couple of hours... that should take care of it
Old 07-10-2008   #53
craig
wants to kick mark
craig's Avatar
Drives: Battery with wheels
wow really? pour some coolant in your oil and call it a day
Old 07-10-2008   #54
mdost03
Sonic Champion!
Drives: VA STI
Here is some inspiration for you:
http://www.youtube.com/watch?v=D2BavfShtZU
Old 01-22-2009   #55
GsXkingGsX
GsXkingGsX's Avatar
Drives: 1997 Eclipse GSX
Send a message via Yahoo to GsXkingGsX
Why would you intentionally blow the engine up?
'97 Eclipse GSX
GsXkingGsX is offline   Reply With Quote
Old 01-22-2009   #56
cmspaz
Walls need hugs too
cmspaz's Avatar
Because he can? Best reason to do anything ever.
Originally Posted by Trogdor
Old 01-22-2009   #57
Why would you intentionally bump this thread?
Old 01-22-2009   #58
Old 01-25-2009   #59
Jungy
Jungy's Avatar
Drives: 10' Sierra Denali & 99' beatervette
I highly doubt this guy is ever gunna come back, which is a good thing, he hasn't posted anything since this thread.
Jungy is offline   Reply With Quote
Old 01-25-2009   #60
He was very proud of spanking escorts and grand prix gt's
