Old 07-24-2008   #601
Re: the evo 3 swap parts are coming
Nice. Too bad it doesn't match your seats
Old 07-24-2008   #602
it will later when I get some grey ultra suede to cover it in. then I can have Ali make a shift boot out of it also. I just have to get enuff to do them and the head liner some time. I can alway just dye it black for now. But hell for 2.00 it was a great deal
Old 07-24-2008   #603
blageo23
AWD4G64
blageo23's Avatar
What temp paint did you use? Also where did you get those stickers?
1998 Spyder AWD
567hp
490tq
Old 07-24-2008   #604
Calipers look great!
Old 07-25-2008   #605
engine 500 paint
hi temp stickers are from ebay they were 7.00 shipped 3 fronts and 3 rears
Old 07-26-2008   #606
Dude you are making some really good progress, the calipers look amazing.
I am just astonished by the shear size of those things, makes me feel retarded for using 2 pot calipers.
Old 08-15-2008   #607
I found a cheap way to tune the car now. I dont have to wait till dsmlink comes out for it. guy on evom set me the files on how to but a evo 7/8 ecu in to the car. nice and easy to do. just going to pick up a evo 8 patch harness so I dont have to cut up the engine harness. I also have to wire in the 4th ecu plug and a obd2 plug that I will just steal from the extra spyder harness.
Old 08-15-2008   #608
Wow, that's awesome. No need for DSMlink at all.
Old 08-15-2008   #609
Freaking sweet! Hello NLTS, direct boost control, boost and wideband logging, and uh, fully tuneable ecu
Old 08-15-2008   #610
Perfect!
Old 08-15-2008   #611
no need for boost control on it yet with the 27psi tial 38 gate but who know mabe run more on e-85
Old 08-15-2008   #612
sweet.
Old 08-15-2008   #613
Wow, that's pretty awesome!
Old 08-17-2008   #614
kevin and I got the 8an fuel lines in the car yesterday and finnished this morring. I taped the rail 8an by 3/8npt and brandon powder coated it hot pink to match the valve cover.
also the 2 other v.c. brandon did for me
Old 08-17-2008   #615
Looking good in the neighborhood.
Awesome news about the evo8 ecu thing.
Old 08-17-2008   #616
I know pink is interesting because it's different, but I'm going to go ahead and recommend you stop where you're at.
Old 08-26-2008   #617
got the evo 8 patch harness today now I just have to find a deal on a evo 8 ecu
Old 08-27-2008   #618
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
Hmm... That looks a lot like the one I just built except yours is cleaner
Evo 8 Ecu? Does the evo 3 and evo 8 match?
Old 08-28-2008   #619
the evo 3 harness is just like a 2g/evo 8 but is obd1 and is missing the 4th plug. So I just have to swap wires on the patch harness wire the 4th plug in and the obd2 plug. I have them extra from the 2nd set of harness for the spyder
Old 09-03-2008   #620
Jon Michael
Jon Michael's Avatar
Ha, now I can bother you on two forums. Any luck finding an ecu yet?
Jon Michael is offline   Reply With Quote
