Old 08-07-2008   #1
mdost03
Sonic Champion!
Drives: VA STI
Did I do this right? Compression Test Results
Alright, I have been having some problems with my car smoking at idle and after doing WOT pulls (floor to higher RPMS, switch gears and as soon as hit gas again, it puffs out smoke).
Finally bought a compression tester today and did a dry and wet test after the car was warmed up to operating temp.
Now, first question, I took all the spark plugs out of the head (instructions told me to) and disabled the coil pack and removed the fuel pump fuse. Was I suppose to remove all spark plugs at the same time or just remove one at a time? Or does that even not matter?
Onto the results, floored for each one and cranked about 6-7 times each cylinder (oil was spraying out of spark plug holes on some tests):
150 150 120 120 Dry
1 2 3 4 (Read from left to right on valve cover)
260 230 230 200 Wet (about 1 tbsp of oil before test in cylinder)
So does this mean my rings are FUBAR? Was told it had a MAP Stage 1 Shortblock rebuild about 15k miles ago only.
