Old 08-15-2008   #2
Re: Fuel Cut #3
It's possibly fuel cut, if you are on stock injectors. The MAFT can't truely get around fuel cut. The only thing it could do is clamp the signal going to ECU, to try to avoid fuel cut, but that has the very dangerous side effect of causing the car to run lean, because it has stopped reporting the real airflow.
