Old 08-28-2008   #11
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
Re: bad idea or terrible idea?
Same here, a small hole to vent wouldn't do that much damage.
I am waiting for a response. If this is his 2.3L I know he just had crank problems and just had it fixed. I think his compression ratio was too high for the timing he was running. His budget to get this fixed was tight already. I don't know if he had to buy a new crank or what.
But after spending all that $$$ and probably owing people just to get the car running and then BOOM all gone. Yeah I would be depressed hating DSM for a while also.
I think there was something else the problem and not the vent system. 2.3L turbo mustangs use that trick
I wonder if he ever changed the spark tables...
