Old 11-24-2008   #1
john
Business as usual
john's Avatar
Re: AWD dsm, rear wheel stuck...
Thanks, I will check that. I figured it wouldn't turn as the other rear wheel was on the ground.
I am pretty much just trying to find out if the wheel bearing is locked up as the wheel wouldn't turn before. I couldn't break it loose while forcing it to turn with the car/motor. It would have to be totally rusted together to be the wheel bearing. Not as likely but possible as it hasn't moved in 2 years.
Thanks
97 Viper GTS
Old 11-24-2008   #2
cmspaz
Walls need hugs too
cmspaz's Avatar
The last time I had to compress a caliper, I used a breaker bar for leverage, and that worked fine, but it just took time.
Originally Posted by Trogdor
Old 11-28-2008   #3
You can't do that on 1g rear brakes. The ebake compresses the piston in the caliper manually, so you need to screw it back in which means unless you can manage it with a screwdriver, you need a special tool to do it.
Old 11-29-2008   #4
john
Business as usual
john's Avatar
I used a needle nose pliers to screw it back in.
97 Viper GTS
