Old 11-26-2008   #18
Re: just got a new winter car 95 mirage coupe
well it has been awhile for pics with the new job it is harder to have time to work on it but I have got stuff done in the last few weeks.
parts installed now
1g brake and clutch peddles modded to fit the rage
evo 8 booster and brake master
evo 8 clutch master
90 dsm engine harness
evo III knuckles with 1g 5lug hubs
also got the 94 7bolt back together
new main and rod bearings
new water pump
extra evo III oil pan I had
oil pump with b.s. kit
new used oil filter housing (thanks Andrew for both the pump and housing for free)
90 non eprom ecu (thanks to green hornet for the ecu for 35.00)
all new gaskets
also put in 1 new exaust valve that was bad and replaced all the valve stem seals.
also just picked up a evo III manifold for 10.00 off ebay the guy thought it was a oem 1g manifold
