Old 11-27-2008   #17
john
Business as usual
john's Avatar
Re: AWD dsm, rear wheel stuck...
Update: The other day I took it all apart and tested the rear caliper by 1) pressing the brake pedal, and 2) turning the piston back in.
The piston moved out and it did screw back in so I am going to give it a try. I started the car, fired right up but had an oil leak by the front case (above/near oil filter sender??).
It was my brother's car and he said it wasn't like that before so I will have to check it over.
As far as the brakes go, if I continue to have problems I will just replace the caliper.
97 Viper GTS
