Old 12-02-2008   #13
mx3twinturbo
mx3twinturbo's Avatar
Drives: StarQuests>>>>>>
Re: HID retrofit discussion
When products are labeled with "no HID" the products lens assembly is correctly matched to the light output of a regular bulb, when a HID is installed the lens basically fractures the light incorrectly making you "beam pattern" worse, and also blinding oncoming drivers making it unsafe for others and you.
It typically has nothing to do with bulb temp, HID bulbs create less heat than a conventional (incandescent) bulb.
and to prove this I did the test stated above.
1987 Conquest- 2.1 project started...
1986 Dodge D-50- S.C. truck 2.6 turbo swap started
1992 Mazda Mx-3- Rear mount twins in progress
1989 Suburban- Project for too Long!!!
"Just Remember, I HATE Drama"
mx3twinturbo is offline   Reply With Quote
