Old 12-03-2008   #17
mx3twinturbo
mx3twinturbo's Avatar
Drives: StarQuests>>>>>>
Re: HID retrofit discussion
I will post up a spec sheet on our product,
1 cold starting electricity 6.5-7.0A
2 stable electricity 3.5A/12V
3 hot starting electricity 3.6A/12V
4 stable power 35W
5 open circuit protection automatic protection in 1s
6 short circuit protection automatic protection in10s
7 over voltage protection automatic stop working reaching18v
8 low voltage protection automatic stop working reaching 8v
9 lighting test no ignition in 23kv anywhere
10 flashing test turn on and off in every second ,every time the bulbs can
11 aging test work continuously 24 hours normally
12 ignition test normal
13 high temperature test work normally reaching 105 centigrade
14 low temperature test work normally reaching minus 40 centigrade
15 waterproof dustproof test immerged in water for 12 hours,
16 anti-vibration test good
17 salt fog test good
18 anti-electromagnetism test meet regulation requirement
19 ignition voltage 23kv 20KV-23KV
20 time to stable in cold starting process 4s
21 isolation function ≥300megohm the power is isolated to outer shell≥300 megohm
if you need an explanation please ask.
Thanks,
Jesse
1987 Conquest- 2.1 project started...
1986 Dodge D-50- S.C. truck 2.6 turbo swap started
1992 Mazda Mx-3- Rear mount twins in progress
1989 Suburban- Project for too Long!!!
"Just Remember, I HATE Drama"
mx3twinturbo is offline   Reply With Quote
