Old 01-02-2009   #6
Re: cant get car started
Listen for the MPI relay when you first turn the key, it's under the center console by the ECU. You can take it out, take off the cover and you'll see if it's blown or not. There's also an MPI fuse right on the positive battery cable, whatever you did with that when wiring up the rear mount battery. Those are always a PITA.
