Old 01-13-2009   #21
wheelhop
Holset's Sex Bitch
wheelhop's Avatar
Drives: 1990 Eclipse, 1991 Eclipse with a little Holset Sex
Re: Holset Turbos
Which hx40 compressor wheel? You should easily reach your goal with that turbo (regardless of which hx40 compressor) and your above list. Keep us posted.
I prefer the bolton hx40 over the hx35/40 any day of the week. Considering the spool speed, go a head and get a turbine that better matchs the compressor. It's good to see you stick with the turbine wheel that better matches the compressor wheel. You can get more out of a smaller bolton housing when you better match your wheels. If you were set on not going over 450 whp, I would say stick with the bolton hx35. I don't see a good place between the *bolton* hx35 and *bolton* hx40 for the hx35/40 hybrid. It probably could eak out over 500whp, but you'll need some healthy boost. The hx35 turbine wheel needs a nice size open turbine housing to get the most out of it and get into the potential of an hx40 compressor.
Matt
Bolton Holset H1C w/ external gate, fp2X cams, DSMLink, 3" exhaust, FMIC, water injection
"There is nothing better for man than to eat, drink, and see good for all his hard work." Solomon
wheelhop is offline   Reply With Quote
