Old 01-19-2009   #10
Re: What oil feed setup are you using, and how is it working out?
I feed my journal bearing turbo off the filter housing, no balance shafts, no porting of the relief valve. I do have the red FP inline -4an filter with the .1 orifice meant for journal bearing turbos, but I only have like 5k miles on it so far. FP told me to check the filter element every 2 or 3 oil changes, I planned on checking it in the next 1k miles. I ordered a few extra filter elements but lost them, luckily they are cheap.
Oh, mine is water cooled as well. And I have no engine oil cooler.
Thanks, I can rest assured knowing someone has a similar oil feed setup as I want, and it works fine! Got one more question, where is the FP inline filter located, near the OFH or the turbo? Does your turbo use a banjo bolt for the turbo inlet?
