Old 03-24-2009   #20
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Re: My Pile Won't Start!
I fixed up all the leaks now on the feed line. I cut off the stock metal line that goes through the pump housing and instead got some brass fittings with barbed ends and sandwiched them in there. No leaks on that end, but when I started it up yesterday to try it out, I now have a leak on the return line.
It's the metal line on top of the tank that takes a 90 degree bend and right where it goes into the tank theres like a pinhole sized leak. So I jb welded it and we'll see if it holds. I might even put a second layer over it today after work now that the first layer has hardened and set up.
I guess if it isn't one thing it's sure as hell going to be another. If I never have to drain that gas tank or smell 92 octane ever again I'll be so happy.
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
