Old 04-03-2009   #5
xveganxcowboyx
Wanker
xveganxcowboyx's Avatar
Drives: 95 M3
Re: A/C Compressor
Get one of the brackets from TKRperformance. You can do washers, but then any time you need to pull the axle you have to keep track of them. If you use a cut part of the factory bracket you can just use the axle bolt hole and the one above it, which will keep it in place when you have to pull the axle.
If for some reason you actually need a compressor and not just the bracket I should have one around. No brackets in my garage though.
