Old 06-13-2009   #8
cmspaz
Walls need hugs too
cmspaz's Avatar
Re: 20 psi on stock 4g63t ?
CEL I'm guessing is something along the lines of fuel trim malfunction. You get it when the ECU is trying to adjust fuel maps past the 12% is allowed to adjust them to compensate for the excess airflow.
The stock fuel cut level is really generous, and the fuel pump can fairly easily handle 20psi to redline. But with stock injectors? Don't push your luck. I wouldn't go past 15psi max.
Originally Posted by Trogdor
