Old 06-27-2009   #16
blackawdtsi
Drives: 2G DSM
Re: Considering stroker, looking for feedback
Improved rod ratio, less cyl wall loading (scuffing) Rings and compression should last longer.
2.4s DO NOT have better rod ratio compared to a 2.3. They use a 100mm crank, just like a 2.3 and the rods are the exact same length (150mm) as a 2.3. However the 2.3 will have lighter pistons, so it's better for high rpms.
UNLESS you're using stroker pistons and longer rods in the 2.4.
