Old 08-12-2009   #11
Re: the evo 3 swap parts are coming
got the radiator and water neck back from John(Pushit2.0) to day. big thanks to him for welding them up. Had the upper hose pipe welded at a 45 and the radiator cap cut off and welded shut. On the water neck it is the evo III bottom and a 1g upper and it is also at a diffrent angle so it will clear the turbo when it get's back I hope soon so I can get the car done.
water neck
also put in the other evo III water pipe I had since I dont need to run the dented pipe any more. Also show's the new angle for the water neck
Dad worked on the radiator. cut some holes in the mounting tabs to install the oem rubber mounts for the radiator and welded in a set of bolts to hold the bottom of the radiator.
the new upper radiator support. We made it a bolt in so the radiator can be taken out with out taking the top mount off the car. It also holds the front and back of the top of the radiator so it does not move at all.
