Old 08-25-2009   #19
Speedfreak
Drives: four tires
Re: Need Pro EZ-Outer
Get a drill bit that is as big or slightly bigger than the stud and start drilling. Once you get to the surface of the manifold the outside of it will just fall off then you can use a vice grip to take the stud out once the manifold is off.
What he said, but you may have a tough time with a drill bit because of the surface of your stud. Grinding it down will probably be your least pain in the arse option. Then either vice grip, or weld something on and ratchet off.
