Old 04-23-2004   #8
DSM97RS
Send a message via AIM to DSM97RS
Originally posted by JasonR@Apr 23 2004, 12:14 AM
serpentine belt or ribbed v for power steering. check it. Take a flash light and check crankcase pulley or also known as harmonic balancer which also holds accessory belts. Probably the tension needs to be adjusted so it is tight enough. loosen adjusting bolt. Once desired tension is met, tighten adjusting bolt and check again. Need correct tools. There are a few people or shops who I would let touch my car if I had too after I have owned and been involved with owning a fast eclipse. Why I do all work. I cannot believe they said replace idler. There is tensioner pulley and idle pulley which timing belt goes around. They must be on LCD OR SMOKIN POT.
i know i need to check the crank pulley, lol, i was asking what i was looking for on it to tell if i need to fix it... and i think you mean LSD
DSM97RS is offline   Reply With Quote
