Old 01-12-2010   #2
Swifty1638
Unsure resident asshole
Swifty1638's Avatar
Re: Fancy Fuel System Questions
kevin, come over and check out my car if you want. My car is twin 310 wallys, run in parallel, through the same setup, to the rail, then -6 to the ported aeromotive FPR (was on josh's stealth back in the day for his 3-pump setup) and then into the stock return. Only issue I had with this, is the fuel filter didn't flow what I needed, and my pumps over flow it. found this on the dyno, and after researching it more, i found the specs on the filter/pumps. I'll be upgrading over winter to something more like what mike (blageo) has on his car. I posted this for the talk guys..see if it helps you:
http://www.dsmtalk.com/forums/showth...=220716&page=2
Black 1GB Mafia #1
744AWHP/526TQ-Shootout mode
639.6AWHP/452TQ-DB's dyno
I wanna go fast.
